Casssandra connection issue
Solved2.14K views17th July 2023Cassandra database localhost
Samuel Gagné [DevOps Member]129 28th December 2021 0 Comments
We are currently experiencing an issue with Dataminer causing all our collectors to not be available. When looking into the errors, we see the following : No connection with the Cassandra database at localhost.
Does anyone ever had this issue ? How can we fix this connection problem ?
Miloš Sedláček [DevOps Advocate]702 Posted 9th February 2023 0 Comments
I experienced the same problem. Here is the reason why I was facing the issue and how I fixed it.
I was doing the migration of the cassandra failover pair (online agent + offline agent) to new HW. The old system was at version 9.6. In the migration process I took the backup of the DMA-main-old (and aimed to remove the DMS.xml from there which has to be done according the documentation, but the file was not already present there) and restored it to the DMA-main-new. All right at this point.
The problem appeared when I then upgraded the DMA-main-new to the 10.1. I was obtaining exactly same alarm as described by you.
After some investigation I found the Cassandra at the DMA-main-new was handling two nodes - 127.0.0.1 and 10.180.11.220 while it had to handle the 127.0.0.1 only. The latter one was the IP address of the DMA-bu-old - the offline agent of the old system. I don't see any other way how it got there but the configuration restoration from the old system.
So I used the nodetool to fix that. The "ghost" node was shown as down so I was allowed to remove it. Here the CLI output
After that I rebooted the server and problem was gone.
Miloš Sedláček [DevOps Advocate] Answered question 9th February 2023
