Cassandra: Unable to compute ceiling for max when histogram overflowed
Solved3.35K views14th December 2021external cassandra node Linux
Alasdair Smith 13th October 2021 0 Comments
We have the following error on a separate Linux Cassandra standalone node:
ERROR [CompactionExecutor:51440] 2021-10-13 09:29:44,536 CassandraDaemon.java:217 - Exception in thread Thread[CompactionExecutor:51440,1,main] java.lang.IllegalStateException: Unable to compute ceiling for max when histogram overflowed
at org.apache.cassandra.utils.EstimatedHistogram.rawMean(EstimatedHistogram.java:231) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.utils.EstimatedHistogram.mean(EstimatedHistogram.java:220) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.io.sstable.metadata.StatsMetadata.getEstimatedDroppableTombstoneRatio(StatsMetadata.java:115) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.io.sstable.format.SSTableReader.getEstimatedDroppableTombstoneRatio(SSTableReader.java:1829) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.db.compaction.AbstractCompactionStrategy.worthDroppingTombstones(AbstractCompactionStrategy.java:387) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.db.compaction.SizeTieredCompactionStrategy.getNextBackgroundSSTables(SizeTieredCompactionStrategy.java:99) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.db.compaction.SizeTieredCompactionStrategy.getNextBackgroundTask(SizeTieredCompactionStrategy.java:183) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.db.compaction.CompactionStrategyManager.getNextBackgroundTask(CompactionStrategyManager.java:119) ~[apache-cassandra-3.7.jar:3.7] at org.apache.cassandra.db.compaction.CompactionManager$BackgroundCompactionCandidate.run(CompactionManager.java:258) ~[apache-cassandra-3.7.jar:3.7] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[na:1.8.0_275] at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[na:1.8.0_275] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[na:1.8.0_275] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [na:1.8.0_275] at java.lang.Thread.run(Thread.java:748) [na:1.8.0_275]
Has anyone come across this before and have an idea of the cause and severity?
It's possibly related to, https://issues.apache.org/jira/browse/CASSANDRA-15164
Thanks for looking.
Alasdair Smith Selected answer as best 14th December 2021
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 14th October 2021 1 Comment
Hi Alasdair,
I would suggest having a look at the table histograms of all your tables (e.g. nodetool tablehistograms SLDMADB data) to see if you can identify which table is causing this. Can you create a ticket on collaboration for Skyline to follow up on this?
Alasdair Smith Posted new comment 14th October 2021
Alasdair Smith commented 14th October 2021
Thank you Michiel, I created a ticket on collaboration.
