Cassandra and OpenSearch Supported Versions
706 views20th February 2026Cassandra opensearch
Berman Hsieh175 23rd September 2025 1 Comment
Hi all.  What is the latest version of Cassandra and OpenSearch that is supported by Skyline?
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 20th February 2026
Simon Declerck [SLC] [DevOps Advocate]1.10K Posted 23rd September 2025 0 Comments
Hi Berman,
You can find the latest supported ranges on our compute requirements.
For Cassandra, DataMiner is compatible with the 4.X ranges including both the 4.0 and 4.1 release branches.
For OpenSearch, DataMiner is compatible with the 2.X range.
Simon Declerck [SLC] [DevOps Advocate] Answered question 23rd September 2025
