Cannot Read Properties of Undefined (Web/Text Component in LCA)
Solved1.03K views27th March 2025
Kobu Selvarajah [DevOps Member]66 25th March 2025 0 Comments
Hello,
When attempting to add a {COMPONENT} feed to an HTML or a Text widget, we receive an error message: "Cannot read properties of undefined (reading 'replace').
This appears to be specific to our application (LCA).  For example, the error still occurs when the existing LCA is duplicated.  On a brand new empty LCA, there are no errors.
Although the page is loaded with errors in the F12 Developer Tool of our web browsers, we're not able to see anything specific to the error message above.
We are currently running DataMiner (10.4.12.0-15149).
Any insights on this issues?
Thank you!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th March 2025
Gilles Bara [SLC] [DevOps Advocate]7.17K Posted 26th March 2025 1 Comment
This issue is most likely caused by the app being in a corrupt state. This corruption can occur when multiple people edit the app simultaneously (which is no longer possible).
To fix the app, follow these steps:
  1. Navigate to:
    C:/Skyline DataMiner/applications/[your app GUID from the URL]/[latest_version]
  2. Open App.config.json and access the Pages folder.
  3. Compare the IDs of Panels and Pages inside App.config.json against the dmadb.json files in the Pages folder.
  4. Remove any file that is not present inside App.config.json.
Once App.config.json is in sync with the files in Pages, the error should disappear.
If your app contains a large number of pages and panels, we can handle this for you, as we have tools to quickly validate it. Feel free to reach out to techsupport@skyline.be in that case.
Kobu Selvarajah [DevOps Member] commented 26th March 2025
Thanks so much Gilles, there was one file that was not inside the App.config.json.
After removing the file and reloading the LCA, we're able to get the functioning {COMPONENT} in the Web and the Text panels.
Thank you again!
