Cannot load complete visio on Edge
Solved3.63K views21st November 2023
S R K Chowdary Alla191 25th October 2023 0 Comments
Dears,
I have an issue only on one PC, where Element has two Frame synchronizers, First synchronizer loads the visio, and able to control , but second synchronizer cannot pull full visio and also no control. It happens only on one PC with all users, But both visios work perfectly on other clients..
Any help?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 21st November 2023
S R K Chowdary Alla191 Posted 17th November 2023 0 Comments
HI Jeeva,
I cannot the see option which U have menionted, as Iam using Edge with DMA ver9.5, But whenever we try to open Selenio visio, iam getting following error below and Visio cannot load the parameters. Please advise.
S R K Chowdary Alla Answered question 17th November 2023
