Can you track deployments into a Dataminer system?
Solved1.63K views17th July 2023#track deployment logs
Reza Biglari [DevOps Member]662 5th July 2023 0 Comments
I want to track deploy frequency into a given production OMS environment.
This means each time we deploy a change to a protocol, a new protocol, new/change to automation script (any code change) I want it to be logged as a production deploy.
In addition to code changes, is there a way to track logs for element/service deployments on a Dataminer system?
Reza Biglari [DevOps Member] Selected answer as best 17th July 2023
Debeuf Klaas [SLC] [DevOps Member]2.00K Posted 5th July 2023 0 Comments
Hi Reza,
An option is that you create an alarm filter on history alarms(information events).
The alarm filter should be  configured with parameter description(by Protocol) and select the DataMiner Element Control Protocol.
With this you can track all different kind of changes to the system.
Regards,
