can we have timer on automation script in order to rerun a method?
Solved1.34K views1st August 2024automation engine automation scipt
Ladan Razeghi [DevOps Catalyst]1.09K 1st August 2024 0 Comments
Ladan Razeghi [DevOps Catalyst] Selected answer as best 1st August 2024
Robin Meurisse [SLC] [DevOps Advocate]1.51K Posted 1st August 2024 0 Comments
Hi Ladan,
As far as I'm aware it's not directly possible to add a timer on an automation script. There are some ways however to trigger it periodically:
  • Create a scheduled task that will run your script for a given interval: every x minutes, hours, days, ... or on certain moments specifically.
  • Trigger the script when an event happens. This could be done with a correlation rule when a certain alarm, information event or a parameter change happens.
  • User Defined APIs.
The following documentation page also contains an overview and link to the mentioned modules. Running Automation scripts | DataMiner Docs
Hope this helps!
