Can we have on Node edge graph for Element IP and hyper to navigate to url?
Solved545 views13th March 2025
Apurva Tandon [DevOps Advocate]1.73K 10th March 2025 0 Comments
Can we have on Node edge graph for Element IP and hyper to navigate to url or script on clicking that hyperlink
Apurva Tandon [DevOps Advocate] Selected answer as best 13th March 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.35K Posted 11th March 2025 0 Comments
Hi Apurva,
In LCAs, you can configure actions to be executed when interacting with nodes/edges. These actions can be executed on (double) click or using the tooltip. Both the 'Navigate to url' & 'Execute script' actions allow using feeds, so they can make use of the selected node/edge data.
