Can we have on Node edge graph for Element IP and hyper to navigate to url?
Solved856 views13th March 2025
Apurva Tandon [DevOps Member]1.73K 10th March 2025 0 Comments
Can we have on Node edge graph for Element IP and hyper to navigate to url or script on clicking that hyperlink
Apurva Tandon [DevOps Member] Selected answer as best 13th March 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.34K Posted 11th March 2025 0 Comments
Hi Apurva,
In LCAs, you can configure actions to be executed when interacting with nodes/edges. These actions can be executed on (double) click or using the tooltip. Both the ‘Navigate to url’ & ‘Execute script’ actions allow using feeds, so they can make use of the selected node/edge data.
