Can we embed an angular or React application inside low code application?
Solved1.39K views19th September 2024
Apurva Tandon [DevOps Member]1.73K 24th July 2024 0 Comments
If we develop a React application or Angualr application in our local, how can we embed that in low code?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th September 2024
Elian Vantomme [SLC] [DevOps Member]269 Posted 24th July 2024 0 Comments
By using the web component, you are able to embed a webpage. This webpage needs to be accessible by the DMA and need to be over HTTPS.
Inside the settings tab of the web component you can specify which webpage the component needs to use by providing a valid URL.
More information about the web component can be found in our docs.
I hope this helps. If you have any further questions, please feel free to reach out.
Kind regards,
