Bypassing Azure Login on DataMiner Cube For SAML-enabled DataMiner Systems
Solved1.30K views23rd January 2025DataMiner Cube login SAML SAML JIT
Reza Biglari [DevOps Member]662 23rd January 2025 0 Comments
Consider a DataMiner system where all DMAs have SAML auth configured. How can a user bypass the auto Azure login and use a local user login?
Reza Biglari [DevOps Member] Selected answer as best 23rd January 2025
Jens Vandewalle [SLC] [DevOps Advocate]10.00K Posted 23rd January 2025 1 Comment
Hi Reza,
When using the desktop application you can hold the SHIFT key when launching the Cube application. This will show you the login screen.
For web apps it’s not possible to log in with a local user when SAML is configured.
Reza Biglari [DevOps Member] Edited comment 23rd January 2025
Reza Biglari [DevOps Member] commented 23rd January 2025
This is uber helpful Jens, thanks! It can also be combined with CTRL when wanting to launch on a new Cube which is nice.
Clarification (if needed) for other readers: Hold shift while launching (clicking on) a DMS on the layout of the Cube landing page. Keep holding shift until login page appears. It didn't work for me to hold it briefly while clicking on a DMS box.
