BPA – GRPC is not the default connection method for InterDma connections for this DMA
66 views2 days agoBPA grpc interdma
Gregor Gielok [DevOps Enabler]164 2 days ago 0 Comments
Hi all,
we have a DMS consisting of a DMA Failover pair and have configured the following settings on both Agents as per Docs :
MaintenanceSettings.txt:
<SLNet>
<EnableDotNetRemoting>false</EnableDotNetRemoting>
</SLNet>
ConnectionSettings.txt:
* type=GRPCConnection
Though we still get the BPA message mentioned in the title. Restarting DataMiner or IIS have not worked for this so far. All the other Tests in BPA have passed. DataMiner Version is 10.6.3.
Any suggestions to narrow down the root cause?
Seppe Dejonckheere [SLC] [DevOps Enabler] Answered question 2 days ago
Seppe Dejonckheere [SLC] [DevOps Enabler]2.82K Posted 2 days ago 1 Comment
Hi Gregor,
Your setup is actually correct, but you are encountering a known issue in the Security Advisory BPA where it would not properly recognize the EnableDotNetRemoting configuration. This issue has been fixed starting from DataMiner 10.6.4.
Kind regards,
Gregor Gielok [DevOps Enabler] Posted new comment 2 days ago
Gregor Gielok [DevOps Enabler] commented 2 days ago
Hi Seppe and thank you for your suggestion! We will check this after our next Maintenance/Update Window. 🙂
