BPA – Configuring thresholds for RTT values in NATS (Supercluster/Leaf nodes config)?
Solved567 views14th December 2025adl2099 NATS RTT SLNet monitoring
Alberto De Luca [DevOps Enabler]5.36K 12th August 2025 0 Comments
In this staging environment I get the following BPA warning for SLNET connections,
yet the RTT value is expected, as this communication involves international WAN link:
is there a way to redefine the assigned thresholds of the BPA for this specific check?
Additional info: 57ms is actually pretty good in terms of WAN link performance for these 2 endpoints - custom NATS topology was implemented in the cluster - and the host with 57ms is a leaf node in terms of NATs config, while the other belongs to the "Core".
Thanks
EDIT: adding DM version info --> DataMiner (10.5.0.0-15943-CU4)
Alberto De Luca [DevOps Enabler] Selected answer as best 14th December 2025
Paulo Henriques [SLC] [DevOps Advocate]1.22K Posted 11th November 2025 3 Comments
Hello Alberto,
In the current implementation of the “Check Cluster SLNet Connections” BPA, the maximum round-trip time is defined as a constant with a fixed value of 50 ms, and therefore cannot be changed.
We will evaluate whether this limit can be made configurable in a future version of the BPA.
Until then, I’m afraid you will need to ignore the warning message being generated.
Cheers,
Paulo
Alberto De Luca [DevOps Enabler] Posted new comment 12th February 2026
Alberto De Luca [DevOps Enabler] commented 13th December 2025
Thanks for your feedback Paulo – feature suggestion added:
https://community.dataminer.services/new-feature-suggestions/configure-or-increase-the-round-trip-time-in-check-cluster-slnet-connections-bpa/
Ad interim, is the rule available on the DMA to tweak that value to 80ms for example?
That would give us a better perception of unexpected delays in our environment.
Paulo Henriques [SLC] [DevOps Advocate] commented 15th December 2025
Hi Alberto,
Thanks for adding the feature request, you already have my vote 🙂
The 50ms is hardcoded as a constant inside the DLL which makes it very difficult to override. The only way would be to manipulate the binary dll directly, which we definitely shouldn’t do.
To give you a more precise idea, below is a snippet from the existing code:
const int MAX_ROUNDTRIP_TIME_MS = 50;
CheckPingReplies(agentResult, MAX_ROUNDTRIP_TIME_MS);
Alberto De Luca [DevOps Enabler] commented 12th February 2026
Thanks to you for the feedback, Paulo
Is there a way this could be achieved by writing a custom BPA rule for clusters distributed around WAN areas?
If we could simply disable/remove the older rule with 50ms and use something that is more current with the nature of our cluster, we may be able to implement this ad-interim while the feature is evaluated.
