Best way to upgrade a failover pair
Solved2.12K views20th December 2022Dataminer DMS upgrade Failover upgrade
Daniel Martinez [DevOps Enabler]144 19th December 2022 0 Comments
I would like to know which policy is the best option to upgrade a failover pair, with the intention to avoid any critical issue during the upgrade and when it is finished.
Which one is recommended?
Marieke Goethals [SLC] [DevOps Catalyst] Answered question 19th December 2022
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 19th December 2022 3 Comments
The recommended policy is "Upgrade main and backup Agent simultaneously". For more information: https://docs.dataminer.services/user-guide/Advanced_Functionality/DataMiner_Agents/Upgrading_a_DMA/Upgrading_a_DataMiner_Agent_in_System_Center.html
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 20th December 2022
Gerwin van der Kamp commented 19th December 2022
Just curious, as why do the other options exist if that is not the recommended way to upgrade?
Marieke Goethals [SLC] [DevOps Catalyst] commented 20th December 2022
The other options are legacy options. These will most likely be removed some time in the future. I’ll make sure this gets clarified in the documentation.
Martinez Daniel commented 20th December 2022
Thanks Marieke!
