Best way to submit fixes in connectors
Solved1.09K views29th January 2025bug fixing Connector Q&A
Gerwin van der Kamp [DevOps Advocate]3.71K 28th January 2025 0 Comments
I've found a small issue in an connector, and fixed that localy, how can i submit this version so that i can run through SLC Q&A and released as an signed version?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 29th January 2025
Stefan Schedletzky [DevOps Advocate]2.48K Posted 28th January 2025 0 Comments
I would say just drop a email to your squad or techsupport 🙂
That's the way I usually take.
Stefan Schedletzky [DevOps Advocate] Answered question 28th January 2025
