best way of monitoring dataminer agents using element in another dataminer agent
Solved2.16K views11th March 2024dataminer monitoring elements
Miao Miao408 7th March 2024 0 Comments
Hi
I have a dataminer pair agents and i would like to monitor the agent pair via an element in another dataminer agent. I would like to get the status information about the agent pair, such as which one is running, which one is stopped, an Alarm if failover happens etc. Is there a way to have an element in another dataminer agent to monitor the agent pair?
Thanks a lot.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 11th March 2024
frans siew [SLC] [DevOps Advocate]1.08K Posted 7th March 2024 0 Comments
Hi Miao Miao,
if it is to get status information regarding a failover setup. There is also the Generic Failover Status connector. Which you could use to alarm the failover status and status details.
frans siew [SLC] [DevOps Advocate] Answered question 7th March 2024
