Best way for converting report to dashboard
Solved1.67K views13th July 2023Dashboards
Bruno Sousa [DevOps Member]669 28th April 2022 0 Comments
Hello,
I have the following report that I would like to migrate to the HTML5 dashboard app:
  1. List of all the elements with state
  2. List of the value of one (or more) parameters for all elements of a given protocol.
What is your advice on the best way to do this?
Thank you.
Best regards
Bruno Sousa
Sebastiaan Dumoulein10 Posted 28th April 2022 0 Comments
Hi Bruno,
Both your examples are both great use cases of GQI queries:
  1. Get elements
  2. Get parameters for elements where
Note that additional operators on these data sets can be added to, for instance, filter or aggregate. There are also different visualizations for your data such as a chart, table or node-edge.
