Azure – Virtual Machines not found
Solved1.89K views12th January 2022Azure
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 11th January 2022 2 Comments
I want to monitor 3 Azure VMs with Microsoft Azure connector version 1.0.0.8 and Microsoft Azure - Virtual Machines connector version 1.0.0.1.
I see that the Virtual Machines is supported:
But it isn't added in the Resource Type Elements overview:
Is there some additional configuration needed before I can see this?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 12th January 2022
João Barraca [SLC] [DevOps Advocate] commented 11th January 2022
Hi Jens,
Can you confirm that the Virtual Machines resources are present in the Resources Table?
Jens Vandewalle [SLC] [DevOps Advocate] commented 11th January 2022
Hi João, those entries are not available. Is that something that needs to get configured in Azure?
Jens Vandewalle [SLC] [DevOps Advocate]10.07K Posted 12th January 2022 0 Comments
In this case the Client ID didn't had enough permissions. Assigning the correct permissions did the job.
