Automation scripts – revoking element selection privilege on confirmation pop-up window.
Solved1.19K views15th January 2025
Daud Ahmed [SLC] [DevOps Member]404 15th January 2025 0 Comments
While executing automation scripts, a pop-up window appears, allowing the user to select the element on which changes will occur. Is it possible to revoke the element selection privilege for operators(not for administrators) on the confirmation pop-up window?
Kind regards,
Daud
Daud Ahmed [SLC] [DevOps Member] Selected answer as best 15th January 2025
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.03K Posted 15th January 2025 0 Comments
If it fits your use-case the Automation script could be executed from a Visio and with the NoConfirmation option the user will not be presented with this UI. That of course means the dummy values would have been passed on from the Visio.
