Automation script throws CrudFailedException while creation in DOM via LCA
Solved1.80K views28th March 2025#automationscript Automation Script DOM CrudFailedException DOM CRUD LCA
Baranisudha Murugesan [DevOps Member]1.19K 3rd September 2024 2 Comments
Hi All,
Im trying to insert a string into my dom section through LCA using automation script and below is the error message im encountering in LCA.
Exception of type 'Skyline.DataMiner.Net.ManagerStore.CrudFailedException' was thrown.
Detailed error:
this is my source code for doing that,
private DomInstance CreateNewWorkflowInstance(DomHelper domHelper)
_engine.Log("CreateNewWorkflowInstance starts here");
var workflowSection = new Section
SectionDefinitionID = Em_Resourcemanagement.Sections.Workflows.Id,
var servicesSection = new Section
SectionDefinitionID = Em_Resourcemanagement.Sections.Services.Id,
var eventsSection = new Section
SectionDefinitionID = Em_Resourcemanagement.Sections.Events.Id,
var resourceSection = new Section
SectionDefinitionID = Em_Resourcemanagement.Sections.Resources.Id,
workflowSection.AddOrReplaceFieldValue(new FieldValue(Em_Resourcemanagement.Sections.Workflows.Event_Workflow_Name, new ValueWrapper<string>(_dialog.WorkflowNameTextBox.Text)));
_engine.Log("AddOrReplaceFieldValue done");
var newPoolInstance = new DomInstance
DomDefinitionId = Em_Resourcemanagement.Definitions.Workflow,
_engine.Log("Created definitions");
newPoolInstance.Sections.Add(workflowSection);
newPoolInstance.Sections.Add(servicesSection);
newPoolInstance.Sections.Add(eventsSection);
newPoolInstance.Sections.Add(resourceSection);
_engine.Log("Added Sections "+newPoolInstance.Sections.Count);
return domHelper.DomInstances.Create(newPoolInstance);
I can see logs until the return statement. but once create is executed, im getting crudfailed exception. There is no further details i can see.
Kindly help me debug what could be wrong here.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the answer (using the ✓ icon)?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Wouter Van Robays [SLC] [DevOps Advocate]1.44K Posted 4th September 2024 0 Comments
Hi Baranisudha,
I can't tell from the screenshot why exactly the create action is failing, because the TraceData is missing. If you check the logfile of the automation module, you should also find the exception, but with the TraceData. Could you provide me with this? This should be logged in the SLAutomation logfile in C:\Skyline DataMiner\logging
On the DomInstance page in the DataMiner Docs you can find all the possible TraceData and an explanation on what they mean.
