automation script parameter select in dashboards
Solved1.38K views15th September 2022automation scipt Dashboard App
Martin Bergström [DevOps Member]20 15th September 2022 0 Comments
Hello
We are developing a automation script that we are planing to have users interact with via dashboard sharing.
We have a memory file with values, the user needs to select which value the script need to use.
when executing the script from a Visio the dropdown shows the description (and the value in brackets)
but in the dashboard app only the value is shown
is there a workaround to displaying the more user friendly “description” field within dashboards app?
Gilles Bara [SLC] [DevOps Advocate] Answered question 15th September 2022
Gilles Bara [SLC] [DevOps Advocate]7.10K Posted 15th September 2022 0 Comments
In the low-code apps you could generate those values through GQI with an ad-hoc datasource and use that query result in a feed that can be linked to that script parameter.
In the dashboards app these linking capabilities are not available and there is currently no way to have the descriptions in there. This is actually an issue, the description should be also displayed in the dashboards app. You can create a task for that on https://collaboration.dataminer.services/, so it can be tracked and tackled accordingly.
