Automation Script – Get current value of RunTimeFlags
Solved1.44K views2nd June 2023Automation script RunTimeFlags
João Severino [SLC] [DevOps Enabler]14.58K 2nd June 2023 0 Comments
It is possible to set and unset the value of the RunTimeFlags from within the C# code of an automation script, however, I have not been able to find a way of retrieving the current value of any of those flags.
If I am developing a method or a library that needs one of those flags active, I would like to be able to leave them as I found them once I am done with my logic so other parts of the code do not suddenly start behaving differently.
Is this something possible?
João Severino [SLC] [DevOps Enabler] Selected answer as best 2nd June 2023
Wouter Demuynck [SLC] [DevOps Advocate]6.83K Posted 2nd June 2023 1 Comment
Unfortunately, as far as I know and can find, there's currently no way to retrieve the current value of these flags.
João Severino [SLC] [DevOps Enabler] commented 2nd June 2023
That is a bit unfortunate.
Although a small thing, I think it would be nice to have and would allow for safer code.
I added this to the Feature Suggestions: https://community.dataminer.services/new-feature-suggestions/automation-script-get-current-value-of-runtimeflags/
