Automation Script Error BadImageFormatException
Solved1.58K views7th December 2022
Julio Riambau [SLC] [DevOps Member]302 27th October 2022 1 Comment
I’m getting the following error after installing an automation dmapp and running the script. It is only happening in one DMA it works properly in other DMA of the cluster.
Script Failure (TestScript): System.BadImageFormatException: The module was expected to contain an assembly manifest. (Exception from HRESULT: 0x80131018)
at CManagedAutomation.RunWrapped(CManagedAutomation* , Int32 iCookie, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* pvarReturn, String scriptName)
at CManagedAutomation.Run(CManagedAutomation* , Int32 iCookie, Char* bstrScriptName, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* varEntryPoint, tagVARIANT* pvarReturn) (CSharp; 0x80004005h): (see comment for more details)
(Script ‘FOX PlayBook Integration’)
Could you please give me some advice on how to fix this situation?
Thanks in advance.
Julio Riambau [SLC] [DevOps Member] Selected answer as best 7th December 2022
Julio Riambau [SLC] [DevOps Member] commented 28th October 2022
issue was fixed by deleting referenced dlls and reinstalling the package
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 7th December 2022 1 Comment
Hi Julio,
can you confirm that deleting those dlls was a workaround or actually something that needed to be done?
Should this be chased further as an issue?
Julio Riambau [SLC] [DevOps Member] Posted new comment 7th December 2022
Julio Riambau [SLC] [DevOps Member] commented 7th December 2022
After deleting the dlls and installing the package the issue has not shown again. No longer an issue
