Automation – How to get the ID from the Agent running the automation script?
Solved2.01K views10th January 2024Automation
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 10th January 2024 0 Comments
I have an install script that gets executed when deploying an application package from the Catalog. In that script I need to create an element and I would like to have it created on the Agent that executes the script. How can I get the Agent ID?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 10th January 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 10th January 2024 0 Comments
Hi Jens,
You can retrieve it from the following property:
Engine.SLNetRaw.ServerDetails.AgentID
