Automation – How to check if a script exists?
Solved837 views9th August 2024Automation
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 9th August 2024 0 Comments
How can I check if an automation script if another one exists before trying to execute it?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 9th August 2024
Robin Meurisse [SLC] [DevOps Advocate]1.45K Posted 9th August 2024 1 Comment
Hi Jens,
One way would be to use the available Skyline.DataMiner.Core.DataMinerSystem.Automation Nuget.
it’s possible to verify if a script exists from the IDms interface (Method ScriptExists | DataMiner Docs).
Kind regards,
Jens Vandewalle [SLC] [DevOps Advocate] commented 9th August 2024
I was hoping there was an engine method, but this will work. Thanks!
