Automation – How do custom entrypoints work?
Solved3.90K views8th October 2020Automation CSharp
16
Joey Vanhalst [SLC] [DevOps Advocate]2.17K 8th October 2020 0 Comments
I'm trying to use custom entrypoints in an Automation script but can't figure out how exactly to use this.
When I add the following C# code in my script, the script can't compile because of syntax errors:
However, when I add an additional Script class (even commented out), the script seems to compile:
The problem is that I can then still not execute my script correctly. The script can only be executed if I add a Script class with a Run method, but then this Run method is used as entrypoint.
Am I doing something wrong or could this feature currently be broken (I have been testing using 10.0.9.0-9365)?
I also noticed that there is not only a "Default" AutomationEntryPointType, but that you can also add an additional "AutomationEntryPointTest" entry point. How does DataMiner determine which one to trigger in case both are defined in your script?
Joey Vanhalst [SLC] [DevOps Advocate] Selected answer as best 8th October 2020
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 8th October 2020 1 Comment
Hi Joey,
Compilation errors issue:
There is some logic in the Automation module that makes it possible to define script code without having to put this in a Run method of the Script class. (You can just type "engine.GenerateInformation("It works");" in the code field, and this will generate the information event.) This only works for script code that can be executed in a single method. When you want to define your own class and use custom entry points, you will have to define the 'Script' class somewhere in the script. The last point in 'Restriction' on the Automation entry points help page also advises to always define this. It also states that it 'is no longer strictly required', but I think this should be revised.
Entry point issue:
When you want to execute a script with an entry point, you need to define the entry point in the  CustomEntryPoint field of an ExecuteScriptMessage.
This is empty for scripts that are executed with the execute button in Cube.
In regards to your last question. DataMiner will thus execute the entry point that was defined in the execute message. A script can have multiple (unique!) entry points.
Joey Vanhalst [SLC] [DevOps Advocate] commented 8th October 2020
Thanks! This answers all my questions 🙂
I’ll follow up with Documentation to update this information so it’s clear in the future.
