Automation c# substring
Solved1.68K views19th January 2023Automation C++
joel Joly489 19th January 2023 0 Comments
Hello DOJO
I am starting to use automation script
I am not using DIS
I need to generate an export text file by using some properties of elements
I am not able to use system functionalities like substring or substr
I hav tried other functionnalities
(string.IsNullOrEmpty(param4) is OK
param4.Split(',')[0]; is OK
Element[] elems = engine.FindElementsInView(28);
for (int i = 0; i < elems.Length; i++)
string param4 = elems[i].ElementName;
string Extractline = "EQUIPSM"+"¤"+"BTBS15"+"¤"+"PARC"+"¤"+ param4 +"¤"+param4.substring(23,7)+"<ATR>";
sr.WriteLine(Extractline);
param4.substring(23,7) give me an error: string does not contain a definition for substring...
Is existing an other way to extract part of strings ?
joel Joly Selected answer as best 19th January 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 19th January 2023 1 Comment
Hi Joel,
'Substring' starts with a capital which is probably the reason you're seeing this exception. Creating automation scripts in DIS would also indicate any syntax errors that are encountered while developing a script.
joel Joly commented 19th January 2023
Thank you Sebastiaan
so easy that I messed it 🙂
