Automation C# code to Comment Alarm without Acknowledging it
Solved1.57K views8th May 2025
Peter Geivaerts [DevOps Advocate]376 7th May 2025 0 Comments
What is the preferred way to put a comment in an alarm without acknowledging it from an Automation Script?
I remember I saw something similar with Engine.SLNet.SendMessage(SetAlarmStateMessage)
Can't find any info about this in the docs.
Peter Geivaerts [DevOps Advocate] Selected answer as best 8th May 2025
Peter Geivaerts [DevOps Advocate]376 Posted 8th May 2025 0 Comments
After a lot of trial and error I found a working solution
SetAlarmStateMessage sam = new SetAlarmStateMessage();
sam.AlarmId = rootAlarmID;
sam.DataMinerID = dmaID;
sam.State = 5; // 2= acknowledge alarm 5= comment
sam.Info = new SA(new string[] { "-1", comment });
engine.SendSLNetMessage(sam);
what Didn't seem to work:
A:
SetAlarmStateMessage sam = new SetAlarmStateMessage(tree, AlarmUserStatus.Comment, comment);
comment);
B:
SetAlarmStateMessage sam = new SetAlarmStateMessage(dmaID, alarmID, 5, comment);
Is there a reason that the use of alarmTreeID (with rootAlarmID) doesn't work?
tested on DataMiner (10.5.0.0-15683-CU2) and use of Skyline.DataMiner.Dev.Automation 10.5.0.2
Peter Geivaerts [DevOps Advocate] Answered question 8th May 2025
