Automation – Assign visual to view
Solved1.94K views24th April 2023Automation Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 21st April 2023 0 Comments
Does someone has some sample code for assigning a visual to a view from in a script? I had a look in the Class Library but couldn't find a method/property on the IDmsView class.
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 24th April 2023
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 21st April 2023 0 Comments
Hi Jens,
Response of Klaas should do it. I'll post a snippet from our RT manager framework, on behalf of completeness: how to create a Visio file + how to set active page on Visio file
private void CreateAndAssignVisioFile(IEngine engine, int viewId, string VisioFile)
    if (CreateVisioFile(engine, $@"C:\\RTManager\\TestDependencies\{VisioFile}", VisioFile))
        var assignRequest = new AssignVisualToViewRequestMessage(viewId, VisioFile)
            ActiveValue = "Active",
            Page = "1",
        // There is no way of knowing if this succeeded
        engine.SendSLNetSingleResponseMessage(assignRequest);
private bool CreateVisioFile(IEngine engine, string filePath, string VisioFile)
    CreateProtocolFileMessage createProtocolFileMessage = new CreateProtocolFileMessage
            What = 7,
            Ba = new BA(System.IO.File.ReadAllBytes(filePath)),
            Sa = new SA(new string[1] { VisioFile })
    CreateProtocolFileResponse createProtocolFileResponse = engine.SendSLNetSingleResponseMessage(createProtocolFileMessage) as CreateProtocolFileResponse;
    if (createProtocolFileResponse == null || createProtocolFileResponse.ErrorCode != 0)
        engine.ExitFail("Could not upload visio file. " + ((createProtocolFileResponse == null) ? "response was null" : $"errocode was {createProtocolFileResponse.ErrorCode}"));
        return false;
    return true;
Matthias Declerck [SLC] [DevOps Advocate] Answered question 21st April 2023
