Automatically clear thread problem alarms in the alarm console if the problem is resolved?
Solved2.15K views6th November 2020Alarm Console alarms
Wouter Bogaert [SLC] [DevOps Enabler]1.28K 6th November 2020 0 Comments
I have some thread problem alarms in the alarm console. When I check the logging I can see they have all been cleared and thus are resolved.
In the alarm console I can also see Thread problem solved alarms.
Is there a way to automatically clear them if they have been resolved or should we always clear them manually?
Wouter Bogaert [SLC] [DevOps Enabler] Selected answer as best 6th November 2020
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 6th November 2020 1 Comment
Hi Wouter,
These notifications you see in the alarmconsole should be cleared manually. There is no way to do it automatically.
Wouter Bogaert [SLC] [DevOps Enabler] commented 6th November 2020
Thanks for the clarification Michaël!
