Audible alerts with web dashboards
Solved2.07K views1st May 2023audible alerts
Gerwin van der Kamp [DevOps Advocate]4.09K 1st May 2023 0 Comments
is it possible to create audible alerts with the dashboards or low code apps?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 1st May 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 1st May 2023 0 Comments
Hi Gerwin,
This is not yet available, but there is an open feature suggestion for it. If this topic gets enough support, we can consider putting it on our roadmap.
Jamie Stutz [SLC] [DevOps Member]1.18K Posted 1st May 2023 3 Comments
While this is not something you can do through a Low Code App as Sebastiaan mentioned, you can do audible alerts through the Skyline Communications Alerter application. You can download the tool at https://[DMA_IP]/root/tools.
From there you can use the Alerter to generate audible alarms. For full details of the Alerter, check out: Accessing Alerter | DataMiner Docs.
I know it’s not exactly what you wanted, but perhaps could still be useful!
Gerwin van der Kamp [DevOps Advocate] Posted new comment 2nd May 2023
Gerwin van der Kamp [DevOps Advocate] commented 1st May 2023
We use the alerter in some places indeed. However i’m looking into getting a simple dashboard on for instance an Raspberry pi to just display some information on the system on a separate system with option to sound an alarm when needed.
Jamie Stutz [SLC] [DevOps Member] commented 1st May 2023
Interesting use case! Until the LCA supports the alert, another idea would be to have some sort of API on the Pi side that could then be triggered from DataMiner via a correlation rule and C#. To minimize coding for the Pi, you could consider using something like Node-RED and a sound triggering node like this one: https://flows.nodered.org/node/node-red-contrib-play-sound. Just thinking out loud. Good luck!
Gerwin van der Kamp [DevOps Advocate] commented 2nd May 2023
Yes, another option can be having VLC with the HTTP/Telnet interface enabled. But i was hoping on a less work to setup way.
