Ateme Titan Edge Protocol
Solved1.43K views6th December 2024Ateme Automation Connector InterApp
Ryan Hepworth [DevOps Advocate]1.67K 5th December 2024 0 Comments
Hi All
Does anyone know if titan edge protocol supports interapp or if there is an AS injection point within the protocol?
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th December 2024
José Silva [SLC] [DevOps Enabler]2.10K Posted 5th December 2024 1 Comment
Hi Ryan,
I did a quick review of the Titan Edge protocol connector (range 1.1.1.x), and didn’t find any implementation of InterApp functionality.
If you’d like to explore how to implement InterApp functionality, I recommend checking out this guide:
Getting started with the InterApp framework | DataMiner Docs
Ryan Hepworth [DevOps Advocate] commented 5th December 2024
Hi Jose, ok no worries.thanks
