Ateme Management System (AMS)
Solved2.07K views20th November 2020
Andy Fairhall [SLC] [DevOps Member]244 4th November 2020 0 Comments
Is it possible to integrate an AMS platform with a DMS?
Will it provide full monitoring & control functionality or are there limitations?
Andy Fairhall [SLC] [DevOps Member] Selected answer as best 20th November 2020
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 5th November 2020 0 Comments
Hi Andy,
As the cluster configuration shares information between the system, such as views, security settings, DMS configuration, etc., we don't recommend to merge as they are different in some ways (e.g. licensing schema and visual skin).
One possible solution is to add a driver that monitors another Skyline Dataminer system retrieving element status and alarms via web services so whenever something happens on the AMS, you can be aware and then go deeper to do any troubleshooting.
