Are DATETIME columns required for tables tied to Indexing Databases?
Solved2.01K views18th July 2024indexing logger logger table logging
Micah Brown [SLC] [DevOps Advocate]600 18th April 2024 1 Comment
On the "Logger Table" documentation it mentions that "One column should be of type "DATETIME"". Does this apply to only logger tables in Cassandra or does this also apply to tables connected to indexing databases?
<Database>
<IndexingOptions enabled="true"></IndexingOptions>
<CQLOptions>
<Clustering>0</Clustering>
</CQLOptions>
</Database>
Micah Brown [SLC] [DevOps Advocate] commented 2nd May 2024
I’m working on an example & NuGet for a SCTE offloader to an indexing database where the SCTE information only includes a timestamp without a date. The table that it’s using for offloading to the indexing database is also not visible on whatever protocol will use it.
Simon Vandamme [SLC] [DevOps Advocate]1.02K Posted 7th May 2024 0 Comments
Hi Micah,
Since the introduction of the Param/Database/Partition@partitionsToKeep attribute, adding a column of type 'DateTime' is not required anymore. That feature was introduced in DataMiner 9.6.0 (See Internal RN 16738).
