Any solution to monitor DNS resolving of STaaS domain names?
Solved722 views6th August 2026Dataminer STaaS DNS STaaS
8
Nils Hoven [DevOps Advocate]1.83K 4th August 2026 0 Comments
for STaaS to function properly, the DMAs need to be able to resolve the STaaS domain names, for western Europe that is
- evhns-cs-prod-weu-001.servicebus.windows.net
- stdmsqueueprodweu.queue.core.windows.net
- cloudstorage-weu.dataminer.services,
by acquiring the needed information with the help of the configured DNS server.
However, in case the DNS server is unreachable or is misconfigured (as was the case recently in our environment), the connection to STaaS fails. This in itself is made visible by corresponding alarms in the DMS.
Does anyone know of some DataMiner implementation already in place or any other way to monitor if the STaaS domain names are actually resolvable and reachable? This can be achieved manually on the DMA, of course, but such a monitoring would contribute directly to identifying the root cause for such a STaaS connection failure more rapidly.
Thanks a lot for your thoughts!
Nils Hoven [DevOps Advocate] Selected answer as best 6th August 2026
Mauro Druwel [SLC] [DevOps Advocate]704 Posted 5th August 2026 4 Comments
Hi Nils,
I can't think of any already existing integration, but others feel free to correct me. I quickly tested it and you can use the Generic Ping connector from the catalog (Generic Ping | Catalog | dataminer.services) for this. You could also write an automation script that tests these endpoints, but the generic ping is the most official implementation.
I have added all three endpoints to this element, as shown in the screenshot. However, the second endpoint you sent is resolvable but not pingable. To test this, I added a fourth endpoint with a non-existent URL. That way, if the DNS server is misconfigured, it will display 'wrong host' instead of 'unreachable'.
I hope this helps!
Brecht Seys [SLC] [DevOps Enabler] Edited comment 12th August 2026
Nils Hoven [DevOps Advocate] commented 5th August 2026
Hi Mauro,
that looks very good indeed, thanks a lot for your feedback and testing! 🙂
I assume, however, that the Generic Ping connector is not free of charge (?)…
Mauro Druwel [SLC] [DevOps Advocate] commented 5th August 2026
Hi Nils, I have no idea, but it depends on the system you're using I think. You get 5 included connectors with the Community Edition if I'm not mistaken. https://docs.dataminer.services/dataminer/About_DataMiner/Pricing/Pricing_Commercial_Models.html#dataminer-community-edition
Brecht Seys [SLC] [DevOps Enabler] commented 6th August 2026
Hi Nils & Mauro
The Generic Ping Connector is free of charge for systems with usage-based commercial model, it gets blacklisted during the monthly billing processing. We still have something on the backlog to indicate this in the Catalog, but it won't be for right away.
Nils Hoven [DevOps Advocate] commented 6th August 2026
Hi Brecht,
very nice! That's much appreciated, thanks a lot for adding this information.
BTW, nice thinking to implement such an indication for free-of-charge connectors! *thumbsup*
Best regards
Nils
