Am I using IDP incorrectly?
Solved609 views29th October 2025IDP
Chris Glover [DevOps Advocate]1.87K 29th October 2025 0 Comments
I'm playing with IDP, but failing dismally to get it to discover anything
Scenario:-
I have an NMOS registry (GV Orbit) running on a device on port 4041. In Admin -> Discovery -> Discovery Profiles I have created a profile called Get_x-nmos. this is configured to GET /x-nmos from the end device on 4041. I create a scan range, that is just my device of interest
In Admin -> CI Types, I have created an NMOS Registry CI type, with discovery identifier confgured
Identifier: Get_x-nmos
Match: contains
Value: registration
If I send a request using cURL, I get
"node/",
"query/",
"registration/",
"system/"
In Provisioning I have configured the Protocol as AMWA NMOS IS-04 Registry, and set the relevant values
However when I run a discover against the Orbit scan range I get nothing. Checking with Wireshark, I can see no requests received by the Orbit sever from Dataminer. other NMOS traffic is flowing correctly
The Orbit and DMA are in the same subnet, and there's no firewalls between them. I can create an element manually, which works correctly
What am I missing?
Thanks
Chris Glover [DevOps Advocate] Selected answer as best 29th October 2025
Chris Glover [DevOps Advocate]1.87K Posted 29th October 2025 0 Comments
Thanks to João, It was due to the IDP Discovery element running on the other site. This is a test system, so not all the firewall rules are in place
After swarming to the same site, it's all good.
The /x-nmos vs x-nmos wasn't the issue
And now I know how to access hidden elements 🙂
Chris Glover [DevOps Advocate] Changed status to publish 29th October 2025
