Alarm “timeout” severity and SNMP forward
Solved2.94K views6th July 2023alarms SNMP Timeout Alarms
Bruno Sousa [DevOps Member]669 13th April 2023 0 Comments
Hello
Can you please tell how can we how can we differentiate the "timeout" severity from others (critical, major, minor, etc.) when we send "timeout" events from Dataminer to a 3rd party system via "SNMP forward" ?
Thank you.
Best regards
Bruno Sousa
Bruno Sousa [DevOps Member]669 Posted 14th April 2023 0 Comments
Thank you both for the suggestions!
Best regards
Bruno Sousa
Bruno Sousa [DevOps Member] Answered question 14th April 2023
