Alarm Grouping per System
Solved2.95K views11th July 2023Alarm Console alarm grouping alarm ID
Francisco Javier Pascual [DevOps Member]79 3rd May 2021 0 Comments
Hello!
we have three different systems in our DMS, each of them with a few equipments, categorized in a tree structure. When an alarm occurs on one equipment , there is no label to distinguish to which system it belongs to. Is it possible to do group or add a Group-ID to identify in the alarm console, to which system belongs the alarmed equipment?
Thanks
Tobe Deprez [SLC] [DevOps Advocate]949 Posted 3rd May 2021 0 Comments
In addition to Simon's answer, you can use Automatic Incident Tracking to automatically group alarms in the alarm console based on what DataMiner detects as the most relevant reason these alarms are there. If you configure the custom element property or the views as Simon suggested, it will group the alarms on view or custom element property if multiple alarms on one of your three systems at the same time.
Note that for these features you will need DataMiner 10.1.2 (for view grouping) or 10.1.4 (for custom alarm property grouping).
