Alarm Condition on Display Key not working on VB Probe element
Solved1.67K views9th January 2025alarm BridgeTech condition VB Probe
Nick Chirumbolo [DevOps Advocate]1.04K 8th January 2025 0 Comments
This seems to only be affecting a specific element on our system (Protocol: Bridge Technologies VB Probe Series, v1.2.0.24). But when using an Alarm Condition for this element, it doesn't work if the condition is referencing a Display Index column (I've confirmed it works on several other columns, including the Primary Index).
Is this a bug, or is there something special about Display Indexes? Or could it be because of the special characters in the VB Probe index (:/-)?
To illustrate here are the settings that don't work:
And these settings do work:
Nick Chirumbolo [DevOps Advocate] Selected answer as best 9th January 2025
Catarina Grilo [SLC] [DevOps Enabler]3.58K Posted 9th January 2025 1 Comment
Hi Nick,
While alarming a discplay key column is not allowed, as referenced in our docs Display keys | DataMiner Docs:
There should be no issue referencing a display key in alarm conditions. However, after testing the driver you mentioned, I noticed that the display key is of type NamingFormat. This particular type appears to have a limitation when it comes to alarm conditions.
I recommend reporting this issue to Techsupport with a detailed explanation of the current situation. They will be able to further assist you.
Nick Chirumbolo [DevOps Advocate] Posted new comment 9th January 2025
Nick Chirumbolo [DevOps Advocate] commented 9th January 2025
Great, thank you I'm opening a ticket now. But just for visibility on here, I am alarming on the "TS Sync" column and only using the DisplayKey for the condition.
