Aggregation on Replicated Element
Solved1.19K views26th June 2025aggregation replication
Nigel Scrivin [DevOps Member]96 6th March 2025 0 Comments
I'm currently finding that aggregation on replicated elements doesn't seem to work.
I've tested the rules on the root DMA and they work fine but I just get no values when creating the rules on the system where the element is replicated.
Can someone confirm if this is expected behavior or possibly a bug?
Thanks,
Catarina Grilo [SLC] [DevOps Enabler]3.63K Posted 10th March 2025 0 Comments
Hi Nigel,
I looked into the documentation on aggregation (About aggregation rules | DataMiner Docs) and found that aggregation seems to be calculated based on real-time parameter values. Since replication elements are essentially snapshots, this does appear to be a limitation of the system.
Additionally, I performed a test of aggregation on replicated elements, and unfortunately, it did not work. This further suggests that this is indeed a limitation.
