Agent alias in system center
Solved1.38K views3rd October 2023
Carys Blackburn [DevOps Advocate]667 3rd October 2023 0 Comments
If the 'Name' field is changed in System Center > Agents > Manage, will this simply update the name/alias and not change any of the agent settings?
Thanks!
Carys Blackburn [DevOps Advocate] Selected answer as best 3rd October 2023
Bert Vandenberghe [SLC] [DevOps Enabler]9.65K Posted 3rd October 2023 1 Comment
You actually have the choice when clicking apply. Either it's only changing the alias, or either it's effectively changing the name of the server also requiring a reboot.
This is the popup:
More info can be found here: Changing the name of a DMA | DataMiner Docs
Carys Blackburn [DevOps Advocate] Posted new comment 3rd October 2023
Carys Blackburn [DevOps Advocate] commented 3rd October 2023
Thanks so much!
