Adding Element Location Using Dataminer IDP
Solved1.92K views6th February 2024
Muhamad Nor Iman Hasan277 5th February 2024 0 Comments
We want to use the Dataminer application IDP to add elements location to the Cube for newly added TX sites in our system.
Appreciate if you could provide the steps to accomplish this?
Thank You!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th February 2024
João Severino [SLC] [DevOps Enabler]14.78K Posted 5th February 2024 0 Comments
In order to manage your elements' locations with IDP you could look into the Facility Management section (docs reference: Facilities | DataMiner Docs)
In there, you should be able to manually assign elements to the corresponding locations and/or configure them automatically based on an automation script that could retrieve that information from an asset management system where you may have such information.
