Adding Element Location Using Dataminer IDP
Solved2.08K views6th February 2024
Muhamad Nor Iman Hasan277 5th February 2024 0 Comments
We want to use the Dataminer application IDP to add elements location to the Cube for newly added TX sites in our system.
Appreciate if you could provide the steps to accomplish this?
Thank You!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th February 2024
João Severino [SLC] [DevOps Enabler]14.91K Posted 5th February 2024 0 Comments
In order to manage your elements’ locations with IDP you could look into the Facility Management section (docs reference: Facilities | DataMiner Docs)
In there, you should be able to manually assign elements to the corresponding locations and/or configure them automatically based on an automation script that could retrieve that information from an asset management system where you may have such information.
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.61K Posted 5th February 2024 0 Comments
Thank you for sharing your question!
After provisioning elements with IDP, you have the option to allocate them to a rack through the Admin > Facilities tab. This process also allows you to create new racks and locations.
If you prefer to set up locations beforehand, you can accomplish this in the Locations section within the same tab.
For additional details, please refer to the Facilities | DataMiner Docs.
Jan-Klaas Kesteloot [SLC] [DevOps Advocate] Answered question 5th February 2024
