Add and Update Element Properties using IDms
Solved2.97K views29th March 2024Connector element properties IDms QAction
Thomas Remmery [SLC] [DevOps Advocate]1.06K 25th July 2023 0 Comments
I need to manipulate Element Properties from code.
I need to add a property to elements that don't have it, and I need to update the value of the property if it wouldn't be correct. I'm using the IDms classes for this from a connector QAction.
I'm able to create the property using IDms.CreateProperty() and assign it to a new element by using a notify call to create it. However most of the element properties seem to be read only when using IDms.
Is IDms able to assign/update element properties?
Tom Waterbley [SLC] [DevOps Enabler] Answered question 29th March 2024
João Severino [SLC] [DevOps Enabler]14.78K Posted 25th July 2023 0 Comments
Hi Thomas,
You need to first cast the property to IWritableProperty as shown in this example
By default, all properties will appear as read-only but you can use the snippet from the link above to determine whether or not they are writable.
João Severino [SLC] [DevOps Enabler] Edited answer 25th July 2023
