add an existing element into a view
Solved2.41K views6th June 2024direct view list view
peng fei212 2nd April 2024 0 Comments
Hi
I have an existing element already in a view and a service. And i created another new view. How could I link or add the existing element under the new view?
What i would like to achieve is one element under multiple views. Is that possible?
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th June 2024
Joshua Wong [SLC] [DevOps Advocate]649 Posted 3rd April 2024 0 Comments
Hi Peng Fei,
That is indeed possible. On the surveyor, you can right-click the element and select "Edit" from the dropdown menu. That will put you on the "edit" tab. Then you can switch tabs to the "views" tab which will show you the views that you have and the view your element is currently in will be checked. You can show the element in multiple views by checking multiple boxes.
This video from our Dataminer Administrator course also details how you can do so (demo is around 29min mark): Elements - DataMiner Dojo
Best Regards,
Joshua
Joshua Wong [SLC] [DevOps Advocate] Answered question 3rd April 2024
