Ad-Hoc datasource assembly load issue
Solved732 views7th November 2025adhoc Missing Assembly Reference SRM
Gerwin van der Kamp [DevOps Advocate]3.74K 7th November 2025 0 Comments
I've got another assembly load issue with an adhoc datasource, we are running 10.5.7. in the adhoc datasource i include an custom nuget which handles dom lookups etc. Part of this nuget is that when linking to an resource it will fetch that resource so we can access that directly. I think that that is where the issue lies since i can do all thing with the nuget until i try to fetch an resources name.
In the nuget we reference Skyline.DataMiner.Core.SRM version 2.0.1 however when i look in error log from the adhoc datasource i do get the following error:
Error in implementation of GetNextPage
System.IO.FileNotFoundException: Could not load file or assembly 'SLManagedAutomation, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
File name: 'SLManagedAutomation, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'
at Skyline.DataMiner.Core.SRM.SrmManagers.get_Default()
at RBM.DataMiner.DOM.Converters.SectionExtensions.GetValue(Section section, FieldDescriptorID fieldDescriptorID, Func`2 messageHandler, Resource& field)
at RBMTielines.Get_nodes()
at RBMTielines.GetNextPage(GetNextPageInputArgs args)
at GQI.ExtensionsWorker.Automation.Extensions.DataSourceWrapper.GetNextPage(IGQIDataSource implementation)
Looking in the dmapp that got created this SRM nuget is not included so i assume it will be included by SRM install itself.
How can i fix this?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 7th November 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 7th November 2025 1 Comment
Hi Gerwin,
I believe SLManagedAutomation.dll has some fixed 32-bit dependencies which do not work in the 64-bit GQI process.
It's recommended to split off this dependency specifically for automation scripts: https://docs.dataminer.services/develop/devguide/GQI_Extensions/GQI_Extensions_Best_Practices.html#do-not-use-skylinedataminerautomation
Gerwin van der Kamp [DevOps Advocate] Posted new comment 7th November 2025
Gerwin van der Kamp [DevOps Advocate] commented 7th November 2025
How can we get the SRM information within an adhoc datasource then?
