A quick way to copy parameter names and PID
Solved1.88K views9th October 2024Shortcut
Bing Herng Chong [SLC] [DevOps Advocate]1.63K 25th September 2024 1 Comment
Hi all, a general question: One of the more common and repetitive actions that I find myself doing is to have to refer to a parameter's name and PID (table, column as well as standalone param). It becomes tedious when there are a number of these to report on and typos creep in. Is there a little-known shortcut to quickly copy these details?
Bing Herng Chong [SLC] [DevOps Advocate] Selected answer as best 9th October 2024
Chirangee lal Verma [DevOps Advocate] commented 25th September 2024
if you have mib file, you can use mib browser in dis for generate param
Miguel Obregon [SLC] [DevOps Catalyst]23.12K Posted 25th September 2024 0 Comments
Hi Bing,
Another possible option is to use the export functionality available in Cube: Generate a list of all parameters in a protocol version.
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 25th September 2024
