integration Use Case
Telestream – Tech Partner Integrations
Telestream
Take a look at this use case to learn how DataMiner Dashboards and Low-Code Apps are used to manage Telestream devices & solutions:
DataMiner offers integrations with a wide range of Telestream products and solutions, such as Telestream Prism, Inspect ST2110, Argus, SPG8000A, Surveyor TS, and many others. For more info, visit our catalog at https://catalog.dataminer.services
This dashboard displays data from Telestream SPG8000A PTP Grandmaster devices and also integrates with a Telestream Prism, functioning as a PTP slave device. Through this setup, DataMiner consistently verifies the proper configuration of both Grandmasters and their reception of the PTP clock from the GNSS source. Prism measures the number of PTP packets sent. Any mismatch between the Grandmaster configuration and Prism's observations on the network triggers an alarm. In this example, a warning shows up when the secondary Grandmaster supersedes the primary one, a situation not ideal for PTP operations.
Presented here is an integration with Telestream Argus, designed to analyze your assets. Simply select an asset, and access the aggregated QoE and QoS metrics for each chosen asset.
Displayed here is a sample DataMiner app that we have built to manage a Telestream Vantage platform. DataMiner keeps track of all Vantage workflows.
User-friendly wizards facilitate the submission of new Vantage jobs. In this case, you can easily initiate a 'Transcode File to DASH' job."
This screenshot depicts the Vantage job history along with various statistics, e.g. the number of HLS & DASH transcode jobs.
1 thought on “Telestream – Tech Partner Integrations”
Where in Catalog is our integration with Telestream Argus?
