integration Use Case
Techex – Tech Partner Integrations
Techex
LAST UPDATED: SEPTEMBER 2023
Have a look at this use case to learn how DataMiner integrates with Techex TXCore (formerly called MWCore) to provide true end-to-end monitoring and control capabilities.
- Techex TXCore
We’ve built a sample application, based on DataMiner’s Low-Code Apps, to provide an intuitive user interface to monitor and manage streams across several Techex TXEdge instances.
On the landing page of our demonstrator app, you can view the total number of TXEdge instances along with a list of all services. Choose an Edge to filter services by TXEdge instance.
In the Services view, you can find more details about each service across all TXEdge instances. This includes a summary of alarms across different layers, such as those related to the transport stream and IP layer. In the lower right corner, the DataMiner node-edge component provides a visual representation of the connectivity.
What sets our app apart is the end-to-end view. DataMiner automatically calculates the connectivity of each service across multiple TXEdge instances, making it incredibly convenient to track your streams from their source all the way to their final destination. Additionally, we've incorporated controls as well, including the ability to stop and resume streams or trigger failovers.
By double-clicking any source or destination, you are redirected to the Node Summary view, which displays the key parameters and metrics for input or output streams.
DataMiner not only ensures that all services are up and running, the DataMiner connector also allows you to monitor the actual TXCore cluster infrastructure.
On the App diagnostics page, we verify system uptime and ensure proper connectivity between DataMiner and TXCore.
5 thoughts on “Techex – Tech Partner Integrations”
This is a very very cool Low-Code App Integration! Excellent work Skyliners, excellent work!
Thanks David and Flavio to make this happen, great job!
Here at Sky we would love to implement this low code app to support our TX Cores and TX Edges. Please let us know how we can get this deployed.
Hello Camille. You can download the APP from our catalog: https://catalog.dataminer.services/details/package/4976. Feel free to drop me an email if you need further help (thomas.gunkel@skyline.be)
This is a nice use case, great job team!
