integration Use Case
Skyline Multicast Flow Tracking
2110 Nevion Cisco
Check out this use case to learn how you can easily troubleshoot the SMPTE ST2110 multicast video and audio flows in your network.
This Flow Tracking application has been rolled out as part of a large-scale DataMiner project to monitor and manage the new IP-based Content Management Center (CMC) at ORF in Austria. Operators needed an easy-to-use tool to troubleshoot and identify the root cause of any multicast flow issue in the ORF production network. For example, in case a mulitcast video flow is not received at a destination, this app will help them analyze where the signal goes missing.
To achieve this, DataMiner interfaces with ORF’s SDN controller (Nevion Video iPath) to learn about active services and the configured paths in the network. Based on those crosspoints, it starts crawling through the network from signal source to destination, comparing the crosspoints that have been set by the SDN controller with the actual situation in the network. To do so, DataMiner interfaces with all devices and data sources along the line, such as the media edge devices and the network switches (Cisco) to achieve a “single pane of glass” user interface.
While the application was purpose-built for ORF, the underlying framework of the application is generic. It can therefore be extended at any time to support other SDN controllers, network switches, and media edge devices from any vendor.
Once the API is available, we will also add support to integrate the EVS Cerebrum Broadcast controller into this application, so that we can extract the flow labels and “bouquets”. Then operators will not only be able to look at individual flows, but also at a bouquet (i.e. a set) of flows.
